part to multibody
  • Thread starter Thread starter Marckmarck
learn how to read the feature manager
There are 7 bodies. (2 profiles u, 4 plates, 1 round). How many should it be?
This is trivial.
There's a sketch. If I had used a face to what would I need to create a sketch?
using a face (what?) how can you hope to correctly divide those bodies?
if you don't put your property manager on the split function, or don't explain Good as you do not have to correct
In shortening tools that I sketch you give, that doesn't make me select one?
but you can't attach the images using the pc (stamp and then paint... gimp or what else? missing part of the property manager!
I hope that what you have attached is the simplified part and that there is something else because otherwise it is not possible to have all those functions. (What does the flange1 board serve for example? )
said that we return to us.
In the meantime, you should show that settings you used to get that horror out.
then, as I wrote, learn to read the feature manager. in mine there are three things: a solid, a sketch and a function. That means I made a special sketch to divide the bodies and that's what you have to do. round contour, U contour and you're fine
It seems that the problem is the flat repetition function, under that I have other functions and does not let me divide, if I split the functions above the flat repetition let me do it.
the flattened repetition must, unless exceptional cases, remain the last of the tree
and I know but I don't know why under I have other functions, can you move it to last now or all the functions I have under I have to do them again?
below I have other functions
Did you shape your eyes closed?
Can I move it for the last time or all the functions I have under it?
drag it and see where you can move it.
do the tutorials, those inside the program not those of youtube, which seems to me miss the basics
If the model you sent me is the complete one you can't have all those functions that will be around 40 eyes.
You've shaped badly anyway. It happens if you are in the beginning. start from scratch thinking about how to do the functions. In my opinion, with a dozen functions, you're the cable.
to insert functions after the flat repetition it is necessary that the latter is active. This should never be done because in case of the need to insert a function on the spreadsheet you must first use the stretch function followed by the fold function.
in fact all functions after flat repetition are suspended because dependent on this
Yes, but now I should have solved, it was the flat function that did not allow me to divide, only that in some pieces I had right at the bottom while in others it was between the functions and I had not noticed.
do the tutorials, those inside the program not those of youtube, which seems to me miss the basics[/QUOTE]However it is not long since I use it and often I realize that with functions and commands that I did not know I could do the same in a simpler and clean way. there is also to say that surely have a more precise idea of how the final piece will help then to model while in this case we are doing tests continuing to change geometries and details that often make me skip mating functions etc.
anyway thanks for the time and the answers! !
for the simplicity of the piece you can do it again in less than 15 minutes....with some desire.
