particular identical but with different name
  • Thread starter Thread starter ddn
ddn
hello to all, to speed up the work, often, I cover the part and input some modifications, but then I have to remake the table because the part has a different name....without using the configurations as you can do? ?
Thanks
you have two systems:
1- copy the part with pack & go of the table and then review with explorer both the new part and the table. I guess the part after the change has a different name than the original one.
2- If you already have the part made, make a copy of the original table, rename it as it must be and then change the references to the table. more precisely press file->open, then select without opening the table, press the reference button on the opening mask and then double click on the reference part and select the new part.
I also happen sometimes and use the second option.
Good job
geppetto82
