passage from cocreate to creo
  • Thread starter Thread starter Graal
Graal
Hello everyone, I am new here and hope to post in the right section!
I'm used to working with cocreates, and now I should go to creo, which from what I understand collects the inheritance.
I would like to know if you can set the interface in I create as much as possible similar to that of cocreate, so as to maintain continuity between the two software, and not have to re-learn from scratch to use one.
Thank you for your help.
you should understand which of these three software you have to pass: create parametric, create direct or eventually create direct/modeling (genialita' of marketing ptc).
If you have to switch to direct/modeling, it's just the same software with a different name. If you have to move to the other two prepared for a big effort: the user interface will be the last of your problems, as it is programs with deeply different logic and approach.
Thank you for your answer!
then, already that there are I would ask you information about the software too. I use cocreate modeling and cocreate drafting. I imagine that the partner I create is created direct/modeling (including drafting?). so from what you tell me there should be no problem with the right interface? If so, you really gave me a great news!
on ptc.com you can download a free and limited version of ptc creo elements/direct modeling express (previously cocreate modeling), so you can get an idea of the interface
Hello.
I confirm that it is indeed so, the old cocreate modeling (or solid designer for nostalgics) for a few years now is officially called ptc creo elements/direct modeling and the old cocreate drafting (or me10 for the usual nostalgics) now is called creo elements/direct drafting. from version 18 onwards the interface has changed (ribbon bar in high msoffice type to mean) .
greetings, stefano
