path constraint in which an object of the group breaks and changes path
  • Thread starter Thread starter Erre1972
Erre1972
Good morning
use 3dstudio by self-taught and for this reason are in difficulty
I have an object with a second object closed in a group. This group follows a path, but at a certain frame, one of the 2 objects must be detached to follow a different and definitive path.
the object that detaches must no longer be bound to the previous path
at the moment I have the group that turns on the path correctly and with keys I have made move the second object but then continues to follow the path of the old group ...
Thank you and I expect a suggestion
If you don't want to explode the group, you could...
1 - make a copy of the object that must follow the new path
2 - add visibility-related, i.e. the first object inserted in the group is visible from frame 0 to the frame in which it must follow the new path; its copy will be hidden from frame 0 until the frame in which it must follow the new path, then becomes visible. of course you will have to asegnate them the new path to follow
thank you for your answer
I had taken this opportunity into consideration, but in fact I was looking for a solution just to detach the object from the group and the memory of the path and to make them perform new movements with the keys
the other object must continue to loop for other frames. . .
