Pavet
  • Thread starter Thread starter francis nerd
francis nerd
Hello, I wanted to open a discussion about the peas.
once you learn to make them.... I'd spend hours...
But at first... I would have given anything not to find them in the factory in the morning....
this discussion and open to anyone who has any questions
or can facilitate our work....
union makes strength!
I look for software ke give me the chance to speed up and automate the big dilemma pave.... .
for what I am here....
in many
but sorry, what is the difficulty you encounter in modeling? If you describe at least the problem you try to solve, perhaps a useful answer could also come to you!? Or not?
then it will also be true that you are in the section of the goldsmiths, but being a forum everyone can read, but they are not obliged to know what is a pavè in oreficeria! Would you explain it to us in broad lines?
from wikipedia:
within the goldsmith the "pavè" is a type of nesting made by setting the very close buds (cutting cut). This system creates a carpet of stones with only one light (reflected). the term "pavè" is taken from the above mentioned terminology of road pavement; in a certain sense the nesting goldsmith fills the jewel by following an order very similar to the rule of the artisan sanpietraio.
I had no idea that the goldsmiths would even have this problem. I thought the term was exclusive use and consumption of the balloons and ceramists! ! !
but the difficulty in what is it?
All of you...
My way of expressing myself sometimes leaves to desire. . .
However in regard to the pave...
I don't have a real problem. .
I want to increase the speed with which I run the pave...
I use rhinogold at the same time for the cutter.. .
rhinoceros for shapes... and arrays for nail cuts.. .
But I miss something....
I wanted to know if there was a software that allows me to click a circle of a certain measure, then click a surface. and its task should be to distribute on this surface in a homogeneous and equidistant way the circles.. .
our task beyond designing,fantasy,etc...and finding the solution easier,effective and fast to get a product.
If we automate all this we would settle a lot of scratches!
beyond my solution to the problem here we talk about a predetermined method to do things...
of course for those who come to your knowledge.. .
his youth must be unequivocal! ! ! ! ! !
I thank you for the availability and grazxie again.... :mixed:
But why isn't the command array in rhinogold? copy polar series?
I am surprised that such a command is not there, now it is widespread in any sofware falls as an alternative filling! But I don't know where to find the hatch you're looking for, I think it's still there.
I command arraycrvplus
I have it on rhino
I move all the ccomands on rhinoceros
anke that of rhinogold
But sincerely, I still found a software that makes me that stuff.
I would halve my work
It would be almost all automated. ...
Would you help me do some research on this software?
I wait for news
I do it differently....
I speak of stones one attached to the other... .
variable surfaces....
and many circles make of this surface a carpet of stones....
if any of you have rhinogold tried to click on a dynamic brick.
then the surface... .
Here's what's wrong....
-cooked stones on a surface: via rhinogold dynamic brick or automatic brick.
-scassatura:taglierina,(and possible also change parameters)
-point:prog.studio (also here change parameters)
-in case of pre-casing: arraycrvplus (clicking the selection from us preset, from the possibility to automatically orientate the section on a curve from us default ke passes in the middle of the stone after doing this you click on profile and then loft.this and the most auitomatized process as I found. . .
Of course, I prefer to talk to people who put their hands down and know something about how much time they lost....
There's only one thing missing...
Does there exist something that allows me to create ke lines pass through the stones dividing them into 4 equal parts?
question and the new question.. .
are we born to design?
and we design anke of the ladders. . .
our work more serene and faster
should... .
but sometimes the nn surface allows you to create holes that allow you to create equal tips between them...
must change according to the space you have....
Forgive me, but I keep struggling to imagine. . . .
The examples could be much more explicit, even those you have rejected are good, so they only serve to get an idea.
but are you so indisposed to post a jpg image? Sorry if I insist, but your descriptions are a little too vague and sometimes incomprehensible. :confused::confused::confused:confused:
I finally managed to see an example, and maybe I had an idea of the difficulties: so I ask you a little patience and expertise in correcting my descriptions.
I understand now that the complexity of the executive entails considerable waste of time; but today I think that a practical solution is still the good and old practice of sharing the executive in equal portions; work them separately, and then gather them in the format of origin.
or generate two identical models and work them in separate mathematics: dividing mathematics into "decoro" and "pavè" and operating on each one with the appropriate carvings.
As for the square of the stones, I think that the difficulty of the program is to work in inclined planes: I refer to the outer surface of the ring. If the pavè builds it up, do you have the same problems as the stones?
generate the matrix in 2d, as a solid developed to understand us, and then build the volume for individual sections.......
but how much do your files weigh? what hw do you have? 32 or 64 bits?
I'm sorry if I'm coming to bring these questions now, but I had to get to understand the kind of difficulty you've encountered. and only thanks to the image I realized!!! ! !
I hope I could explain. Hi.
First of all, I thank you for your concern
with regard to the possibility to put on the table the cuts (under 2d)nn it could be done since the subdivision in 4 of the stones would go to move from the central point given that to then project it on the surface they would go to move the central points of the stones so nn you can do.
It is necessary to work on the surface if we talk about cuts. .
I use rhino4 32bit I have 3 gb of ram.
As for the nn file I can show nothing since the company nn designs must be shown. . .
but I can do nothing.
Please, but if you went to a forum I assume you need it!
I don't need production drawings, but purely explanatory geometric examples: axes, lines, circles, and their positioning. . .
I don't think the numerical data of how many mb or kb weight your work files is a sensitive data of confidentiality.....in any case I follow!
would you want to waste some more words to make the second sentence of your post understandable? I find it a little difficult to see concretely: that's why the images are sometimes more than a thousand words resolute!
hello and good day
this could be a test image!!!
Of course the carvings are missing because I have not understood their geometry well! ! !
