pdf 3d viste esplose
  • Thread starter Thread starter lustro
lustro
Hello everyone!
after searching long and wide for the forum:smile: I couldn't find anything that could give me some slight indication or limit a little suggestion.
I'm drawings for my friend (parts, boards, etc.), from which I write the various pdfs so that he can send them to whom he wants. but a small problem arises: he has seen around that some with swx (I have 2007..sorry) manage to make the pdf 3d (and up to here easy.. I can also I:biggrin: ) of the assemblies (yet easy :biggrin: ) esplosi :eek: ..and here I go in crisis because I tried in various ways but I can not.
bad luck is that I don't even have a file to see how it was done.. or at least to get the secrets!!! !
Does anyone have any suggestions to give me?? ? ?
Thank you so much!! ! ! !
pdf creator and other similar virtual printers create pdf 2nd e non 3d (for now, unfortunately).
That's right! !
sorry if I first specified well, but in pdf 3d one can rotate the component and see it from all the various angles (more or less as if it were in the environment of the cad), it is a mobile pdf (so to say!)
At the limit there are difficulties if one wanted to measure the piece, but for now this is a problem that does not exist.
other tips? ? ?
did you save the pdf 3d from the model? Now I can't do proof, the alternative could be edrawing in exe.
What do you mean by "saving the pdf 3d from the model"? ? ?
I have a set made from details 1, 2 and 3 and of the axieme I have the configuration mounted (say so) and the configuration exploded.
of every single detail 1, 2 and 3 I do the pdf 3d (simple, a save by name and I am in place); then the mounted axieme still saves me the pdf 3d (always simple, always saved by name), then if I put the axieme in the configuration exploded and save it in pdf 3d... always comes me out as mounted: what am I wrong in my steps?? ? ? ?
If you have no copyright issues, you can attach the assembly here and the exploded parts (in .sat format) so I try with acrobat.
the investigated design is a little too heavy to attach.
Now I see at work if I have something ready (more or less), I do a couple of tests and then I see to attach it!
(only that the last and only time I saved a nn client in sat was able to open them...nn know if for problems of my swx or his cad....in any way after I try!)
I can't save them in .sat format!!! !
only pulls me out of .err files!!!! !
Goddamn it!!!! ! ! ! ! ! ! ! ! ! ! ! ! ! ! !
(I swx 2008 sp 0!!! ! !
I'm on a course today, so I couldn't take care of it before the week. .
make sure the assembly is in the center (as a planet), and the parts exploded all around (type satellites), thanks.
I tried with 2010 and saving in pdf3d with the current configuration "exploded", also the pdf is exploded. The only thing is I can't put the flow lines in the 3D, but I didn't look at it very much, maybe it's possible to get that too. Maybe your release is too old.
Bye.
Bye.
I did it myself, activate the exploded configuration, save the file and then save it by name in pdf 3d, but it always makes me the version not exploded.... .
I think then it is my release too old.... what stressful question!! ! !
Does anyone have any suggestions?? ? ? ?
I know there was a bug on sw2008, but not inherent to the explosive views.
I know there was a tool made by solidworks labs, but I never checked out the explosive views and then they picked it up.
Maybe it had to be integrated into solidworks but they didn't.
However I also with sw2011 and acrobat x can not export a combination with explosive view in pdf 3d format.
hunter succeeds with sw2010 and xp pro.
So I don't know if it's a sw2011, acrobat x or seven or seven to 64-bit.
Anyway, I'm not the only one who can't do it, so it makes me think of some software reason.
