pdf command export problem
  • Thread starter Thread starter MAURO2480
MAURO2480
good morning to all, I submit a problem with revit2023 that I respond during the export stage in pdf:
using the command “export pdf” (the icon on the top left, white and red and blue arrow, placed next to the “print” command), the export obtained shows in the quota texts that have been modified (through the command “replace text” with unique control character nads numerical forms) the nads indication before the value of the modified quota.
I would like to understand how to avoid the pdf.
known problem. use the "print" command to support a virtual pdf printer (e.g. pdf 995 or cutepdf) instead of the "export pdf" command
p.s. replacing the quota text in revit is a blasphemy
Thank you, perfectly agree that it is a blasphemy but in this case I needed... :
