pdf di a0 allungato
  • Thread starter Thread starter zanna83
zanna83
Does anyone know if it is possible to publish a pdf of a table on an elongated a0 sheet, or a double a0?
using the wf command and not a virtual stamapante.
in the settings menu doesn't seem to have found anything useful.
I have the version wf5 (creo?) m080
Grace
it would miss, set the sheet with the size you want and expose it in pdf.
the interface has changed a bit, the print in pdf you find it under public.
I always use the good and old macros, I do first.
Following that procedure I don't do it, I have the doubt that something should be set on the config but I have no idea what.
doing as you rightly say you do me well all the sizes up to the normal a0, but if I make a double a0 I cut the drawing with the dimensional limits of the a0
config.pro has nothing to do with the press formats, it is very strange what happens to you.
I from wf3 I have always used custom sheet size without problems.
What version of pro/e use?
i mean I have wf5 m080
I don't know the other versions, first I worked with solid edge
what command are you using to do pdf, in detail?
with file-save copy... specifying the type "pdf", it is well an elongated a0.
both by saving copy\pdf
both doing from the public menu by checking the pdf box
the result is the same:
I set a double a0 sheet and print a simple a0 sheet by cutting what is right
I can't understand what doesn't work, I've done a lot of tests and I don't have this problem.
try contacting ptc support.
