pdf line thicknesses
  • Thread starter Thread starter PiE81
PiE81
Good morning.
both saving and printing (via virtual printer) in pdf, I find inadequate line thicknesses; or too large and make the design illegible.
the problem mainly matches with big details, on which I make a fairly push reduction scale, type 1:20.
Is there a way to solve this problem?
You could get a modest reduction in thickness by minimizing the thickness of the lines but you'll be upset.
I recommend you change the design format using an a0 (or what you need) and scale as little as possible, so the problem does not exist, when you save it in pdf, or print it directly with catia, the a4 format typical of the common printers is automatically recognized.
obviously with the format a0 the characters of the writings and quotas being proportional to the large format appear small as readable only if printed in a0, but finished the design with a "traplone" selections and imposed all the characters to the maximum format
