pdf of the "real" aviation history
  • Thread starter Thread starter l'attempata
two different problems, lubrication and power supply.
lubrication concerned oil pumps that were unable to work at negative g.
the power was about the fuel pump that couldn't pump the fuel.
variants on the theme, which could be added, were the problems of fishing the usual pumps, and not least the carburetors who with negative g were unable to control the fuel level in the tanks.
In short, a real triple of problems, every engine/aircraft, had a combination/permutation of all these problems, moral the reverse flight was forbidden, prolonged beats as well.... :
to find a person with a greater availability than his already great competence is rare. thank you heart er president
I can't open the pdf from the third chapter onwards.dice damaged file, thanks for the help.
known for the authors: it is a work with a detailed history and a pleasant exhibition that also attracts the profanes like me.
Great job!! :
I have now downloaded all chapters and display them correctly; for display I use pdf architect 7.
did you do the right procedure to reassemble the various parts?
1) you need to download the three zip files
2) you have to save them in the same folder
3) double-click the first file (works even if you click on the other two)
4) will open winrar showing you the reassembled pdf file
5) double-click the pdf file inside the winrar window and open the file in your pdf viewer.
Great job!! :
is the work of one of the founding fathers of cad3d, a person of exceptional human and cultural thickness. Unfortunately, it's time he doesn't go to the forum anymore.
Great job!! :
Nothing to do, it always tells me damaged files. what I do not understand is why the first two chapters open them directly.thanks for the answer.
there is another user who has encountered problems with the third chapter (see page 3 of this discussion), so sandra_me30, in a post always on the same page, reloaded the 2nd and 3rd part.rar of the third chapter, then try (if you have not already done) to download these files.
If you still have problems writing it, then I will give you the link to access the pdf with all the chapters already assembled (105 mb).
Have you already made me the stone? ? ? ?
I came to cry when I saw the date of the 1st draft of the " reunited editors_me30 ", 2007.
1/3, almost, of the working life of us poor tapini.
thank you er President for these 1054 pages.
