pdm and file name
  • Thread starter Thread starter New Rider
New Rider
Hey, guys.
I wanted to ask an info given my inexperience with the pdm of solidworks.. .
We start from where I work without pdm.
I create the particular, I save it inside a folder with my article code for es.123 and I make the table.
at this point I will have a 3d model with relative table that will both bring code 123 within my folder.
with the pdm is the same thing? I was told that when you create a 3d model and then save it with the pdm he creates a fictitious code both of the model and consequently of the table that does not correspond to my article code.
i.e. I will ultimately have article 123 code in the folder but if I go to do a search through windows or I go to physically search the file inside the folder I will not find 123 but the fictitious code generated by the pdm.
I hope I've been clear. . .
Hey, guys.
Hi, I use the pdm solidworks and I can tell you that it is not so. what they wanted to say to you is that you can set the pdm to have an automatic coding, with code detachment generated automatically by the pdm according to set rules. go quietly, if you save a file with a name even at the table generated automatically the same file name will be proposed.
