Alex_M
I forgot... Thanks to you too! You know how to explain the things that a kid would understand.made the 3d you have practically also the 2d because the projections are extracted automatically by 3d, and being a parametric cad if you change something suits the views of the 2d is updated.
It is here that the speech comes out that certain things must be studied and cannot go to tentons. However I try to explain better the concept of tolerance.
tolerance has already been said to be an area of margin, dimensional or geometric, which is assigned to an entity. This tolerance declares how much I can afford to move from the ideal measure, we call it theoretical zero, because it has to be maintained the functionality of the entity in its context.
but this tolerance serves to ensure interchangeability with other equal entities; If I make a pin that must be assembled in wool or in belgium with a cylinder made in canada or in congo I must be sure that the assembly is always correct even if I have to rotate these components among them.
to do this, each component has a standard measure; knowing that the theoretical zero does not exist is assigned a tolerance. This is the concept at the base of tolerance.
Start reading somethingDismac. unipg.it/common_files/drawing/_8_dimensional tolerances.pdf
http://www.edutecnica.it/meccanica/tolleranze/tolleranze.htmhttp://www.federica.unina.it/ingegn...triale/tolleranze-dimensionali-parte-seconda/but if you are looking for the forum you will find it in bizzeffe of discussions that treat the topic
