perspective
  • Thread starter Thread starter Hope
Hope
Good morning.
I'm a nx neophyte... Can you tell me where I can find the "perspective" command in version 6 to avoid the cut of the model?
Thank you! ! ! !
What do you mean the cut of the model?? ?
I forgot.. 19 posts without a presentation are not a nice business card:wink:
Hi. I presented:
I solved the problem... even if I only got lucky!
practically importing the model from nx-proe converter or iges or parasolid at the opening I displayed the model as if it had had a dynamic section i.e. I saw the model cut from the "screen" plane.
I read in a previous message (here on the forum) that this is due to the excessive size of the part but that changing the "perspective" variable I would have solved (in nx3).
but I didn't find that variable in nx6..
then typing on the icon "suitable to screen size", the one with the two arrows on the cross to mean, the model appeared well!
Thanks anyway for the answer!
Good day
hope
thanks for the presentation, now we know who you are:smile:
your actually is not a real problem, it is a viewing gap.
and what you did is correct.
If, for example, I zoom out on a 3d piece, I obviously see the circles as segmented, but after a regeneration and vision, everything optimally and the graphics card uses its memory to load the detail. if I leave the zooom the amount of details becomes excessive for graphics and consequently loses pieces, the adjustment resets these settings.
I would also recommend setting parameters in preferences -> display performance mafari by making an evaluation of the graphics to activate or not certain settings .
soon
