phino
  • Thread starter Thread starter lorenzomarro
lorenzomarro
Hello, everyone, they're at first with rhino, so I don't know where to put my hands......... .
I have made a 3d model (a sort of diamond) made by a number of floors, what I should do is physically realize this model, in wood, so I would need the measurements of every single face to realize them, my wooden model must have a width max of 130 cm...this and the only measure I have available... I'll put you a picture of the model so you get a clearer idea. .
Let me know. .
try to explode it, then select each face, the orienti parallel to the plane c and take the measurements. Remember to mark on the 3d model the surfaces:smile:
or use the "sviluppasrf" command (or "_unrollsrf"), you should automatically get the result of the operation that suggests harm (including the edge marking, with the label option).
then you can quote the size of each surface
developsrf works with developable surfaces, so to the eye your model has all flat faces so you should not have problems.
great paolino!!! or did these operations: I selected groups of faces, and copied into different levels, each group then exploded with the command developsrf (which exploded the polygon the faces arranged next to the other parallel to plan c) now how do I have the measurements of each triangle? and then another thing...I would have to change the size of the model,I need a max width of 130 cm..........how do I do?
Now how do I get the measurements of every single triangle?
I would say that you can quote them with the command quote... or if you prefer to analyze/length...
Well, that depends on what you want to get. . you can help with scale controls and solid editing commands
