"phone" more texts together
  • Thread starter Thread starter IN.TEC
IN.TEC
Good morning to all,
I wanted to ask you if someone has already solved a problem that I banged our teeth yesterday...
I had more texts, imported from a table of a dwg, in a set.
I wanted for practicality to manage notes in cartiglio merge all the texts in a single multiline text without making all the copy/paste for every text I had.
You know if there's a solution? ? ?
Faithful
I really didn't want to create attributes but really merge texts into a single multiline text happy all others.
tir the command suggested by you only transforms the text into mtext but does not melt the contents of the texts.
Maybe I explained badly in the first post.
I have so many text with various contents copied from several drawings, in particular notes placed on constructive drawings.
now on indication of my client wants me to bring back all the notes scattered on the various constructives in the axieme.
for my better text management in layout I wanted to put all notes in single mtext with multiple lines.
what I didn't want to do is copy/paste every single text to put them in a multiline that contains all the other texts.
I wanted to know if there was a special command or a lisp that could help me.
Faithful
[Quello che non volevo fare è fare copia/incolla di ogni singolo testo per metterle in one multilinea containing all other texts.
Faithful[/QUOTE]I'm sorry, maybe I'm wrong, but the multiline that focuses on texts?
You are right xxfast.. .
I explained badly.. .
I meant multi-rigue. that is a text with multiple rows to head.
tir the command suggested by you only transforms me text in mtext but does not me blend the contents of the texts.
Faithful
He does,
in the options you have to select create word-wrap mtext
