photoport
  • Thread starter Thread starter Franco Giorgi
Franco Giorgi
I can't hide the viewport panel line in the shiny presentation.
when I mold all viewports appear twisted and some intersect in an improposable manner.
I've been looking for the manual, but I can't handle it.
Maybe I answer myself.
I sprayed the answer given by lory and I have to remove thickness and filling before creating crop in glossy design.
tonight I try because at work they use autocad (sic!)
That's right!
you can double-click the viewport and edit the crop by removing the line and filling thickness. in this way solve.
same thing, when you create the viewport and draw a polygon that delimites it, remember to eliminate thickness and filling.
I do.
Thank you very much.
After studying well the 2d I am going to pass to the 3d coming from rhino in windows. I will be resentful for the thousand problems I will encounter.
Thanks again.
franc
remember that you are on a program well different from rhino, which is born for modeling. vw is basically a bim, has parametric objects for architecture. It also has tools for modeling, but it is not born for that. :-)
I do.
excuse lory, but your projects are not medellati with vectorworks? (type palace of venetian cinema? )
Yes, we do everything with vw in the studio. using it for a long time we have a certain mastery. However, it is less versatile than a modeling software.
I do.
In fact, it is my intention to get to do everything with vw. I don't know why but I like the idea of being able to use as soft as possible. modeling and 2d only with vw are already a nice result for me, plus I seem to have read somewhere that even the imaginations can be made in vw with excellent results. . .
