numero1
but really the 3d model is in the design you post, just rotate the view
in top view everything looks perfect and two-dimensional but so it is not.
perhaps you should be a little + careful, in fact turning the view you see other strange things, for example the section a-a is not all on the same plane; but it's put up more than a z up and down... like standing in the roller coaster.
summing up:
1) fix 3d solid errors, such as bevels
2) fix solid 3d so that it is a solid 3d and not 4 or 5 (as now)
3) carry the cartilage on the layout and leave on the model space only the solid
4) Using autocad uses solid 3d to get plants, views and sections (on the layout)
5) compare what you will get with what you did until now
6) apply the layers you have already created conveniently and delete all the superfluous
summing up:
