MBT
mand
Suppose we have a set composed of various elements that can be moved, coupled one to another.
to carry out movement I have, correct me if I'm wrong, two methods:
or I bind all components to a skeleton and, commanding the skeleton quotas, I move the elements
or I don't use the skeleton but I put the pieces between them with the pin bond (or similar)
the first system allows to use "exact" odds and position the pieces precisely, but it is slow and slender
the second allows to "draw" the pieces until they get the desired position quickly, but it is unpredictable
if I wanted both solutions?
I mean... have a skeleton that I can enable or disable. If disabled, I can drag the components. if enabled, change the parameters in the skeleton
or the possibility to see and control the positioning quotas of the pins...
is it possible? ?
Thank you very much
is it possible? ?
Thank you very much
