GianniM
ciauz
I was making some scarabs with inventor when I met this problem.
I have two tubes, like a plant, created with the frame generator. from the tilted tube I would remove the volume with the sampling, to get the exact design. How can I remove all the excess? with the command “notch” I remain attached to pieces that then touches me by opening the part and making extrusions. a method that seems very rough, and very laborious if to repeat many times.
