erf
Hello, guys.
I press that I did before searching the internet to find answer to my question, but I did not find a really satisfactory answer.
However the problem is this: I have to model a tubular chassis of a vehicle, before doing this, however, I have to do simulations on a t joint between two circular section tubes. Since this joint I must then import it into ansys, I wanted to shape the joint in 3 different ways:
1) Extrusion sweep along the path with full section
2) Extrusion sweep along path with hollow section
3) Long-path sweep surface
the question I ask you is: Is there a command that with options 2 and 3 allows me to block the sweep when you meet another body (the sweep is done on paths related to the average lines of the tubes)?
I add that I cannot use the structural element function (for reasons of import and because it does not like my prof!) so much less the simple extrusion because in the frame the extrusion takes place, in general, on curvilinear trajectories.
Thank you!
Thank you!
