piping - create line id
VincenzoF
Good evening.
as the title of the debate already explains, I need to create in the working environment "piping" a line id.
But I have this message back:
set a directory with access in writing for line lists in the project file xmlI don't have any idea what it wants, or at least I can find a project.xml file on my pc, in nessusa installation directory.
Good evening.
win
good afternoon win,
I had your own problem and I solved it like this:
- go to the path c:\programdata\dassaultsystemes\catenv and open the file catia.v5rxx.bx.txt i.e. the environment file of the catia version you have installed;
- you will find the catdisciplinepath= environment variable with an unspecified path;
- add after = the path c:\program files\dassault systemes\b19\intel_a\startup\equipmentandsystems\projectdata; so you set the directory you need;
- start caia and choose the piping or piping module
- select in the menu above tools -> projectmanagement -> select/browse
- in the box select project and in the disciplines box choose tubing or piping depending on the form in which you are and then confirm with ok.
the created lineid function should now be enabled.
I hope I've been helpful.
I'm sorry.
hi to everyone I also have the same problem, I followed your guide but I can't make it work.
