planimetria e fosso
  • Thread starter Thread starter alpearchitetto
alpearchitetto
Hello gfranco,
Every now and then I wake up with the nightmares of revit. then I attach the image file of a section relating to an old project developed by our former collaborator (brava and for this reason he left us for more interesting ideas).
I do not dilute myself on the problems x interpret what he had achieved but I come to the firm
I read the various posts but sn old and reported to 2008 now I use 2010 then the arrow "read" indicates where there is a roar. well entering into change planimetry and trying to adjust the relative quotas I can not return the depth of the ditch but it seems almost that "ship" over the surrounding land. I have tried all of them including the creation of a subregion but nada de nada.
from the top of your 1830 mm you can give me that straight.
:4410:
if the bed of the ditch was created using the quota points of the topographic surface, you must search for them, and change the quota (planimetria>modifica>...) "spegnendo" the objects and families that are above.
for water must check how it was made (check the object and then change family ...)
if a mass has been used (in-place) I think you have to remake all the ditch water...
if the profile of the ditch is of constant section, i.e. constant traits between one section and the other, the water can be made by extrusion of "on-path unions" between several consecutive sections, if instead the section is constant (and unique) uses an extrusion on the path
ps ...1930 mm...
thanks gfranco prezzzzzzzzzzzzziose instructions I have to understand what used the previous hand then I let you know, kind and precise cm always.:finger: but when you find the time x reply:confused:
Well cmq compliments x the 1930 mm in extrusion if it was the tombola of the parish I would probably have won.
:36_6_6:
hello and excuse if I write beyond the due;o) ball said alex
but I don't know what to say I've tried all of them:
- change the quotas in planner;
- union of pathways > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >
- help to help online
nada de nata I solved, for now with rendering that show everything apart from the kaiser channel the brandenburg.
the fact that it was designed with a thousand levels and I do not understand it + a bat.
Okay, well, tomorrow I'm in superintendency speremm, but then I'm banging the pumpkin will be a solution.
Thanks gfrank
:36_1_4:
