Debora___
Hello everyone, I just joined the forum because I am facing a problem in designing an internal door panel for cars for a university project. some research shows that the most common material is polypropylene, therefore plastic. the associated legislation would be din 16901. should this rule be indicated on the paper? if yes, it is correct to indicate din 16901 mk? Moreover, they contain plastic materials, in the definition of dimensional and geometric tolerances, do you follow the same approach used for metal materials?
