plot: advice
  • Thread starter Thread starter Geppetto82
Geppetto82
hello to everyone, I am always me and always at the sockets with the usual gate! !
I can't figure out how to horizontally put the brick plot into the vertical part of the fence wall.
I'll attach the picture to you.
Giuseppe
first of all you have to "map" the single face and not the whole solid. (if you're not already doing this)
in the "advanced" tab of the material you find all the positioning bars (offsets uv for example), including one for rotation. .
Hello c3kkos,
Thanks for the answer.
I actually didn't map every single face, but the whole solid.
Now what I ask you is why my screen is different from yours?
I'll get you an image.
I wish I could give the same size of mapping to every face,
but I can't find the command. in your screen I see that you can manually insert dimensions (over rotation) maybe that's what I need?
But there's no...
for the moment I have to do it by hand, increasing or decreasing the square that appears on every single face.
But there's no...
enable the photoworks, you will have additional options that will allow you
also save your texture with the desired size.
