I uploaded the lips and this happens, sorry but I haven't used for a long time autocad, instead of that symbol I would like to put that green ball, is it feasible? Thank you.
the display of the point entity is managed by variables that set its size and graphic representation.
the point as it is understood in autocad point is a reference entity, it has no substance, such as a line, so much so that to be intercepted you must have the snap point activated.
what you want instead is a circle with full sampling or a block.
are two conceptually different things in autocad
@massivonweizen I totally agree.
another option to create a "pallino", in addition to the circle with sampling and block (which I personally prefer), is the use of a polyline (more laborious but still feasible).
Let's see @ luca _ 0232 provides other details, but my impression is that I want to insert a block with progressive numbering (tiro ad guess).
I see it complicated.
for the ball it is enough to identify, in the lisp, where it inserts the point and change it (for example) with a donut (ring).
for the numbering it can be inserted, but according to the order in which the lisp identifies the intersections (which does not necessarily have a logic for those who read/produce the design).
Maybe put the point "2" here and the "3" happens on the other side of the sheet.. .
In fact, the lisp suggestion from @mello de is a clean and well-expressed code, and it is also simple to locate the line to change.@leggera As for the numbering, I think it as you, it would be a complication, even making the numbering from below up and from left to right... cmq I think it's better to wait for a response from @ luca _ 0232
