rinato
Hello everyone, drawing molds (for sheet metal, cold), I often find myself embarrassed to have to choose whether to use steel or polyurethane springs for the Premiere and similar.
That is, I, instinctively, put in the first choice steel, then maybe with the holder we analyze the first drafting and he leans for the rubber.
apart from cases where nitrogen cylinders are needed, what do you prefer, at equal load, for molds from a few thousand pieces/year?
I have also lost some time and I have "calculated" that the iso10243 yellow springs has the same rigidity of the imgs soft imgs in polyurethane 90°sh, but these last always last me little, or after a few hundred cycles go often because they have lost the preload on the road. while the steel springs work a lot and then they drop all of a sudden (and we would miss ...) .
Will there be any makeup for rubber springs that is not written in the catalogues?
Greetings, reborn.
Greetings, reborn.
