position odds, balls and vision titles at varying scale
diegodl71
Good morning and thank you in advance to those who will answer me.
I am automating as much as possible a table of a prefabricated beam that is generated by varying the parameters of an axieme with personalized level of detail controlled by ilogic rules.
having in an a3 communicate some views to the production control their scale with an ilogic rule, so that they always occupy the same space on the sheet.
to vary the scale of a view of a beam I would like the odds, the pallinations, the titles of the sight to be at a constant distance from a reference that could be a line representing the geometry of the beam or the origin of the sight.
While at the varying size of the beam the quotas remain bound to the geometry at a fixed distance, in the case of variation of scale such quotas undergo a kind of adaptation of scale that leads to move away or approaching that reference line which I would rather remain at a fixed distance.
as you see the image confirms my statement: If I cover the left view and then decrease the scale of representation, the odds approach the beam until it becomes unreadable.trave T rov  PARA.webpIs there a procedure that can maintain such quotas at a fixed distance from certain segments? This would avoid losing time in repositioning these quotas. alternatively, is there a way to place the text of the vertical quotas to the right of the quota line and not to the left, or in the horizontal quotas to place the text below the quota line and not above?
thanks for the attention
