Hi.I should place the vertical plate so that the highlighted face matches the blue edge, how do I? in the various constraints I do not find the coincidence with a edge. igo image
Bye!in the bond options I do not find edge - surface, yes are: coincident, distance, normal, tangentece others that now I do not remember (I am not on the machine where I create) ....the two surfaces are not orthogonal.
for my little experience, the most "solid" system of all is to create a floor in halfway on the perforated outer bracket, idem on the plate you want to place, and constraints between them the planes.I would have another positioning problem, I should place a plate at a certain distance not having flat surfaces to refer to, attach image.
I'd do the same thing.for my little experience, the most "solid" system of all is to create a floor in halfway on the perforated outer bracket, idem on the plate you want to place, and constraints between them the planes.
(I usually, unless special needs, I realize my pieces as symmetrical as possible: In your case, it would be enough to coincide with 2 floors of the main tares).
I fully agree... and I remember that it is very important not to miss the plan:wink:for my little experience, the most "solid" system of all is to create a floor in halfway on the perforated outer bracket, idem on the plate you want to place, and constraints between them the planes.
you know how much I have taken to heart this pearl of wisdom! :wink::finger:I fully agree... and I remember that it is very important not to miss the plan:wink:
I know, I know, but I don't miss a chance to refresh my memory. we can not afford attentionyou know how much I have taken to heart this pearl of wisdom! :wink::finger:
