Dador
Good morning to all!!!!
Attached you will find a .par file resulting from a 3d scan of a bottle on 4 levels (the first to 13 mm from the xy axis, then 50,72 and 107 mm).
And all right here.
If you rotate the object so as to see it from above, you will notice that it is not aligned with yz and xz plans. Moreover, the sections you see are not regular, they are the union of many small segments.
my problem is to give these sections a planar reference, perhaps exploiting the planar surface, like cutting the section with two floors creating 4 areas as similar as possible .... I say .... ! ! !
thanks from now on for the help !!!
And all right here.
