post-processing con femap
  • Thread starter Thread starter Tyrahel
Tyrahel
hi to all! I would appeal to your insindacabile experience: I imported, assigned the properties, meshato, finally assigned loads and constraints to my model, a biella, with femap v.10.After that I exported the model (command export/analisys model in the menu file) setting static options for the analysis and nx nastran as solutor, but not entering the detail of the various options
I forgot...the title of my femap window already says femap with nx nastran and allows to carry out the analysis but with the same results above.is it really necessary to export the model or femap incorporates the solutor?
excuse the petulanza but for completeness I bring back the log file of the analysis; in case someone knows how to interpret it:
nx nastran v6.0 (x86 family 15 model 43 stepping 1 windows xp service pack 2) control file:
nastran buffsize=8193 $(c:/programs/femapv10/nastran/conf/nast6.rcf[2])
nastran real=533463040 $(program default)
jid='c:/documents and settings/tyrahel/desktop/progetto/simulazione modulo fem solidedge biella/analisi/biell001.dat'
out='c:/documents and settings/tyrahel/desktop/progetto/simulazione modulo fem solidedge biella/analisi/biell001'
mem=48705536
mach='x86 family 15 model 43 stepping 1'
oper='windows xp'
osv='service pack 2'
model='amd athlon(tm) 64 x2 dual core processor 4200+ (lello-63e14a5f1)'
nproc='2'
config=4
nproc=2
symbol=deldir='c:/programmi/femapv10/nastran/nxn6/nast/del' $(program default)
symbol=demodir='c:/programmi/femapv10/nastran/nxn6/nast/demo' $(program default)
symbol=sssalterdir='c:/programmi/femapv10/nastran/nxn6/nast/misc/sssalter' $(program default)
symbol=tpldir='c:/programmi/femapv10/nastran/nxn6/nast/tpl' $(program default)
sdir='c:/scratch/biell001.t3644_14'
dbs='c:/scratch/biell001.t3644_14'
scr=yes
newdel='c:/programmi/femapv10/nastran/nxn6/i386/sss'
del='nxndef'
auth='28000@localhost'
authque=0
msgcat='c:/programmi/femapv10/nastran/nxn6/i386/analysis.msg'
msgdest='f06'
prog=femap
nxn_ishellpath=c:\programmi\femapv10\nastran\bin
nxn_jidpath=
path=c:/programmi/femapv10/nastran/nxn6/i386;c:\windows\system32;c:\windows;c:\windows\system32\wbem;c:\programmi\amd\mcat\;c:\programmi\ati technologies\ati.ace\core-static;c:\programmi\file comuni\nero\lib\
current dir: c:\documents and settings\tyrahel\desktop\progetto\simulazione modulo fem solidedge biella\analisi
executable: c:/programmi/femapv10/nastran/nxn6/i386/analysis.exe
nxn_msg: stderr
fpe: yes
current resource limits:
physical memory: 2047 mb
physical memory available: 1235 mb
paging file size: 3939 mb
paging file size available: 3296 mb
virtual memory: 2047 mb
virtual memory available: 2031 mb
nx nastran started mon sep 7 08:31:15 oseo 2009
08:31:15 beginning analysis
all 3dnow! and mmx extensions operations have been enabled.
all sse xmm operations have been enabled.
all mmx operations have been enabled.
08:31:15 nsinit: *** nsinit error 70 *** unable to open unit 8
08:31:15 nsinit: stop
08:31:15 analysis complete 3
fortran stop nsinit/nsclose
real: 0.031 seconds ( 0:00:00.031)
user: 0.015 seconds ( 0:00:00.015)
sys: 0.000 seconds ( 0:00:00.000)
nx nastran finished mon sep 7 08:31:15 oseo 2009
the message reported in f06:
08:31:15 nsinit: [Bleep] nsinit error 70 [Blessed to open unit 8]
indicates that you have update issues. all versions of nx nastran and versions prior to 2005 r2 since April 1, 2009 suffer from this problem.
talked about kissing on April 1st in various posts of this site.
you have to get a patch for the software from your dealer.
in any case to view the results you must load the *.op2 or *.xdb. in the *.f06 file there are the results to read and not those to load in the post processor. for what I know I use patran!
Staff online
