post processor featurecam con xbuild
  • Thread starter Thread starter e.ferriani
e.ferriani
I am working with a brother tc32b who does not accept the character "_" (underscore). for now I found only this, maybe there are others: who speaks.
with featurecam every time I put an fc space puts an underscore. is it possible to prevent this, perhaps there is a tick somewhere, or in the postprocessor made with xbuild put a program line that converts this character with another, e.g. "-" or "space"?
If you mean space in the comments or in the names of the tools, I with the mitsubishi had the same problem and I solved it immediately putting one point between one word and the other.
If, for example, you name a tool by writing "point hss d.3" the fc will write "point_hss_d.3".
So, since then and in all such cases, I write things like "point.hss.d.3".
the comment remains legible in the car and the underscores disappear.
vabbà ̈, but the fc points do not accept me :finger: so if I wanted to title the "siana" feature with frieze ø10.5 r0.4" I must necessarily write "siana with frisa ø10p5 r0p4", then lun naturally puts the "_" to the box of space, then "spiana_con_fresa_ø4p5_r0 I am using 2010 but also the previous 2 revisions I had were equal.
Now... Then let us understand each other better.
If you're talking about the features names, unfortunately, so it's and there's nothing to do.
while instead in the comments and names of the tools, which then go into the machine blocks, you can put any character, provided of course that then these characters are accepted by the cnc.
So the question, please, is another: but do you want to insert in the machine program the names of the features under the form of comments?
If the answer is positive, I'm afraid, and I repeat, that there's nothing to do, as the famous low indent is a default always in fc and I think it's never going to change.
If you just don't want to do without such calls, then I think the only way is to process the machine program further, directly from the featurecam window nc and before saving it, changing all the underscores present through the "replace" function (menu accessible with the right button while you are in the text window).
That's what I mean. I had noticed after some evidence and research that there is no way to prevent fc from removing _ or letting other things put. What I wanted to do was to turn back the machine code after its creation. This could create "casini". I thought there was a way to put in the psp a command line where to resign to remove all _ and to put that I know about spaces, - or points.
