post processor tips
  • Thread starter Thread starter wf52
wf52
Good day to all:smile: I've been using the mastercam x4 version for a month, with small problems with the post processors that are bringing me to the delirio :mad:
when I launch a contour (even in 2d) the machine stands out saying that tolerances exceed the permitted values.
I'm gonna press that I already called the car suppliers to get to know the settings.
Is there anyone who can tell me how to solve this problem? ? .
What control does your car have?
if it is an osai-ecs-isac-sed it is quite simple to make a pp for the 3 axes real
also post a simple program that gives you error.. type a circle arch
Okay.
I don't know the cn
The manuals you find here http://content.heidenhain.de/doku/t...242135142603/1242135142627/1242135142627.htmlI took a quick look and it doesn't seem like anything transcendental even if different from the "programming" I know...
0 begin pgm fk1 mm
1 blk form 0.1 z x+0 y+0 z-20 definition rough piece
2 blk form 0.2 x+100 y+100 z+0
3 tool def 1 l+0 r+10 tool definition
4 tool call 1 z s500 call tool
5 l z+250 r0 fmax tooling
6 l x-20 y+30 r0 fmax tool preposition
7 l z-10 r0 f1000 m3 positioning at machining depth
8 appr ct x+2 y+30 cca90 r+5 rl f250 approach to profile on a circle with tangential connection
9 fc dr- r18 clsd+ ccx+20 ccy+30 fk section:
10 flt programming for each profile element known data
11 fct dr 15 ccx+50 ccy+75
12
13 fct dr 15 ccx+75 ccy+20
14
15 fct dr 18 clsd- ccx+20 ccy+30
16 dep ct cca90 r+5 f1000 profile detachment on a circle with tangential connection
17 l x-30 y+0 r0 fmax
18 l z+250 r0 fmax m2 tool failure, end of the program
19 end pgm fk1 mm
Hi, I gave a leaflet to the manual, and or ran some tests on a 415 overhead control and the alarm is identical. I think there's some point in the post that prevents work.
hi, but you're recalling the macro functions of the cnc, I've seen that you usually use the heidenhain language where there are the instructions l,cc,c... .
