postprocessor generator pertopsolid
  • Thread starter Thread starter allumi
allumi
Hello, someone knows what postprocessor generator software
is compatible with topsolid?
are not very satisfied with the postprocessor provided by distributors
together with tp.
everyone and nobody.
in the sense that if you have the post that comes out with the neutral file (type apt or cl-data) , all post-processing programs manage well (or bad) to turn it into g-code (see icam.com so much to make the idea).
wanting you could also reprocess the g-code but logically you would lose information.
If you have an already done post you can also change it, but here is a little more difficult:
try to take a look at the topsolid American and French forums.
I believe that the Italian distributors of ts provide service and therefore modifications pp.....quiries and will be given to you:) ... their programmer is a phenomenon, I guarantee it;)
Otherwise, if you want to put hands on your own, you should take a look at the .ini file that you find in the pp folder.... is that the configuration file of the whole pp.... is a simple text file that you could interpret!
Good job
hi, I don't discuss the professionalism of pp assistants, but as usual
is the user who asks something strange, that had never happened before, that maybe I did not turn on the pc and not mene I noticed, and so on,
in beyond the .ini file I have already manipulated it, but there are several limits, as
I can not reduce, for example, the shifts in "z" (intensive as a axis depth) return, approach, security etc. etc. in cases where processing requires more than one pass.
anyway thanks the same to be interested.
hi allumi in fact to reduce the z movements on the most past you can put in the table parameters the item only re-alire if necessary, or disable the voice only if necessary you can insert in the climb between the past the voice no if you do not want to go back or absolute if you want to go back to the origin piece or relative if you want to go back to the previous pass.
