powershape
  • Thread starter Thread starter pirataviola
pirataviola
I sometimes happen to be able to perform some operations because with different surfaces because it gives me the message.. nn surfaces have the same number of isocurves....but how do you give the same number of isocurves equal to both surfaces?
you have to add/remove them manually, to remove them you must select them and delete them with the appropriate command/icon (eye that you do not deform too much the surface), instead to add them first you click single on a parameter point, then press the ctrl on the keyboard, and until you hold ctrl "transcini" the parameter along the surface.
If you want to add them via a command that inserts them into an exact point (for example, if you want to insert one exactly halfway between number 3 and number 4 already existing, launch the command and write 3.5 in the available field). this form/command also has other more advanced options, such as inserting one from wireframe etc, but it is too laborious to explain it without showing it, especially before you understand everything I have already written here above
