precise scaling
  • Thread starter Thread starter Da Vinci
Da Vinci
Hello friends, I make a synthetic example: I have a solid length 100mm. I want to climb proportionally and make it 81mm long. exists a command in rhino where I write 81mm and automatically the solid scale proportionally from 100mm to 81mm?
thanks to who will answer.
I believe there is no cad. the scale command always works with a factor, if from 100 you have to take it to 81 steps x a factor of 0.81.
exists. .
1.
Select objects.
2.specification a origin.
3.type the scale factor or select two reference points.
to scale an arbitrary object in a specific scale
1.use the source point and the first reference point to determine the original size of the object.
2.type the new size for the second reference point.
