zimmy Guest Sep 4, 2009 #1 Hi. Can someone tell me where to read the precision value in the step file? Thank you. p
mali_fx Guest Sep 4, 2009 #2 ''modifies-set-precision-immise value'' and shows you the default tolerance.
zimmy Guest Sep 4, 2009 #3 I explained badly. I meant to know the accuracy with which the step file was generated and that I am importing into proe. in iges file the precision of generation is in position 19. in the step file? Thank you.
Momy985 Guest Sep 4, 2009 #4 What do you mean by position 19? you have to check the acuracy of the model, relative(0.0012) and absolute(0.0001) edit»setup»accuracy
