luiging.
in creating a nesting file for cutting a prepreg skin, I found a strange problem. This file is part of a long series of files that I have created following the same steps and using the same save formats, but this file in particular seems corrupt. in detail I proceed as follows.
using special software I get 2d templates from 3d mathematics. the templates are in dxf format. the amount in autocad and I process them by correcting the profiles and any artifices. I set the layers, one for cutting and one for writing, respectively 0 and 3. I organize a new nested file and save all in dxf. I send it to the cutting department and usually everything works. this file in particular manifests a strange and for now irresoluble problem: part of the square is decomposed. a portion of about 1 meter left and another portion with the writing layer is transferred rigidly to the right. This effect is not visible either on autocads of other stations, nor on draftsight..... visualization, layers..... is always correct. when loaded on the cutting machine station is corrupted in the manner I described. (the cutting machine is a bullmer and the station uses a dedicated proprietary software)
resolution ideas?
similar experiences?
half of yesterday's day we have it (underline two, I new engineer with the support, though not massive, of an engineer who has been working in the industry for 8 years) spent looking for solutions that we did not find. in order:
- copy paste the placed into a new file
- recomposition from zero of the nesting with integral recreation of the writing layer
- recomposition from zero of nesting with integral recreation of the writing layer with a macos system
- layer verification
- verification of the correctness of geometries
- obviously check the file extension
- as I have already said check with other cads and other posts
Does anyone have any idea, in addition to the tautological but remarkably frustrating, to redevelop the dimes from scratch?
thanks to all those who will dedicate time to answer
resolution ideas?
