press issue with autocad 2008
Paso
cdt I have a problem with prints on autocad 2008.
The problem is that if I print a drawing on a3 format, everything is regular and the lines appear to me all, while when printing on a2 format at a0, the print comes out with missing lines, type texts with missing pieces, missing quota lines and other things like that.
for example type la and without one of the horizontal lines.
the problem concerns the horizontal lines.
Thank you in advance who will help me!
probably is a printer memory problem.
Make a try: instead of directly printing dwg, create plts for printing or pdfs, to see if you can solve the problem in this other way.
I would say it's just a memory problem, it happened to me when I was printing on solid edge plotter, increased memory, solved the problem.
Bye.
the fact is that since it is a network plotter and that my other colleagues, with the same kind of drawings have no problem, I know it is a problem of my pc!
Help!
missing data:
1) plotter: brand and model?
(hp designjet 500 or earlier suffer from similar problems)
2) your colleagues year the same cad?
(if your colleagues year the 2008 version and you 2009 the problem is all there. from 2009 onwards, the press requires more memory ... it is not an official but statistical data ... I happened on about fifty customers with the passage from 2008 to 2009. )
3) how many retinals and how many shades?
(they start a lot. and removing them and printing goes well is a 100% memo problem)
then the model of the plotter is:
1) designjet 800ps 42 by hp
2) the cad is 2008 for everyone.
3) no net only lines and bows with writings, but very complicated as drawings, but it is the same for all my colleagues.
Thanks for the answers!
Strange, a 800ps is a great car!
First of all, since you've spent a lot on the ps instead of the normal 800, are you using the ps drivers, right?
Is it not that you are using the pcl5 drivers or worse still pcl6 for printing?
Are other users microsoft windows view ?
I don't know what kind of drivers I have.
in the office only I have windows view, the other all xp.
in the properties there is written:
hp print driver designjet v5.35
and cmq is also written that are drivers shared with other users!
ah... seen where the discriminant... our good old sight... nausea.
Well... yes... pcl v5.53 is the one supplied with the cd of the car... vetusti!
note well: from the known response a certain "confidence failure" at least with the drivers of the operating system. are therefore to strongly recommend that the installation of the drivers is made by a colleague / technician.
try to use these:
- per vista a 32 bit
- per vista a 64 bitGood luck.
