Vale-Ria Guest Sep 5, 2019 #21 Now he tells me he doesn't find the variable drag. Am I wrong to type something?
Vale-Ria Guest Sep 5, 2019 #23 because here Suit mode there was this phrase "this system variable has the same name as a command. to access the variable, use the modvar command".
Vale-Ria Guest Sep 5, 2019 #24 unveiled the ark! ! I didn't understand the right command. Now it works... . Thank you:
