leom81
Hello everyone
As in the company where I work nobody cares about it, I would like to try to see if you can improve the system we work with.
In practice, we make steel furniture for the naval sector.
as a program we use microstation v8i.
our work is done so: there is a drawing together, in which we create a cartiglio, and above this is made a table, in which all the various codes of the components that make up the furniture of the assembly are inserted.
l together has a code a005000001 and the components can have different codes depending on whether they are of purchase or internal production, for example a002000002 or a002000003 if of internal production or v003000001 if of purchase.
when a piece of furniture is sent into production, a paper is made containing the drawing together and the various drawings that make it, so every time you have to make a piece and maybe in the future reuse it, you have to print one by one the various drawings that make it, and with plics from even more than 50 drawings, open every design and print it takes a long time, so I have come to mind one thing: to automate the printing of the plics.
I'll explain. I would like to see if you can create a procedure, possibly also the use of other programs, as well as microstations, which allows you to automatically print a whole piece, simply by typing the general code of furniture.
Is it possible to get that?
