print sizes larger than one a3 in think
  • Thread starter Thread starter helynor
helynor
good day to all this is my problem:
I need to print an a1 or a0 format on think design, the problem is that for formats above the a3 the program stops, saying that memory is insufficient, of course if I printed in a3 and then enlarge the image would grow. I hope I've been clear. thanks in advance
Good morning, my name is carlo
I work with the 2008 version, could you tell me which version you have?
molds by checking the top left batch box on the print window,
or molds in custom form then without popping up the batch box?
Save I use the 2010 version when I go to customize the print size, do not spell the batch box, should I?
another thing: When I try to check the batch box, you tell me I didn't install think print, how do I install it? I didn't find xke on the internet. thanks in advance
think print allows you to print automatically, and to do this you check the batch box, but it is not indispensable, you can safely do the custom print, see the steps:
from the press select file drop-down menu,
opens the window and to the item name imposed the desired printer, click on the "i" to the right of the name box and imposed the sheet format and orientation,
then click on page and under the window imposed "personalized"
after which I click on the brake (on the right of "personalized") and select the desired print area,
levels = all
thickness=colors
remain to set the margins and print parameters
but I don't think they're relevant.
at this point I bring myself to the drop-down menu file
and click on "print preview"
if all ok click on the box at the top right of the window to confirm printing,
Let's see if with four steps you solve.
However, this may not concern the program, but the printer/plotter you use. I sometimes try to open the design with another program but it gives me the same mistake.stampo, however, normally both a1 and a0 with thinkdesign.
sometimes not to fight long with the file or program just print the drawing in pdf and then print the pdf to the desired format.
