printing architectural boards
  • Thread starter Thread starter saluzzidan
saluzzidan
Hey, guys.
I wanted to know how you set the architectural tables for the press.
I'll explain.
When you present a project you usually have to attach cadastral sheets, prg strawberries and other plans.
My problem is that by importing the image files of the above-mentioned plans in the table of revit I have a lean print quality.
I had already written before that the images are imported only to 72 dpi without possibility to modify them, so very low resolution.
I tried to export the revit file as an image and then work with photoshop for the pictures, but here I have the opposite problem: even if I imposed a resolution of 600 dpi in export the raster file becomes me of 96 dpi and the drawing lines quite wide.
Can someone give me a few tips to figure out how the project tables in question are presented? (dia, permission to build. . . )
Daniele
I amount the pictures that make up the catalytic extracts, the prg zoning and the actual photos in drawing or normal views, shot at very high levels, without any quality problem, indeed... you can also do directly on the press board.
rather you have to set the very high print quality on the plotter... .
I repeat, the print quality of these images for me is more than excellent. :
Hi roberto,
Thanks for the answer.
Can you make me understand the procedure well? you insert images with the command "file - import/connect - image"?
because I do so, but whatever the quality of the image revit me turns it into a 72 dpi and the press loses a mess.. .
I don't know if I have to set some special options.
a greeting
Daniele
I checked the data, which are gray, therefore not mofidificabili, in the properties of the elements and in fact all report 72 dpi (see attachment).
What does that mean? probably is the confirmation of what I already told you: it is a problem of setting up prints.
how do I train you? try and let you know... .
Okay, looks like it works.
I actually inserted the pictures with a very high resolution (300-600 dpi) and in print quality remains good.
thanks and the next.. .
