probable new user.
graziano-g
hi, probably in February I will start a new business adventure in a company that uses this program.
I couldn't find a trial version, or it's too easy and I don't see it or I'm stunned but the result is the same....
Can anyone help me?
Can anyone help me?
have solved the problem of activation?
As far as I know, lately, after installing it, you can't activate it.
I honestly didn't know anything about it. have you tried to write to the support?
have made more than one request in the community and I have tried to install the express version several times, to try it, but none of the times I managed to activate it even following the instructions of recent posts.
That's why I was wondering if the problem was solved.
I'll try again! even if I have already done it ten times in different times, following the instructions of more post and on different pcs.
Hello, in fact... activation problems continue.
ask the customer code or send the basic version: Where the hell is the basic version?
hi, if I update the commune
Are you sure that by "base" version is not the basic ptc account, for which no customer number is required since it is something "less than the customer account" ?Creazione Utente Base.webp
Sorry. @kaji , but I recorded myself more than once with the basic profile (for correctness, I sent request to the ptc assistance to remove previous recordings) and contacted to solve the activation problem (unresolved).
First error, activation is not completed because the application fails to access the activation server (I have no special configurations and it is the only one that creates this problem).
as you know, the next step is to take you to their page to generate activation code (temporaneous), three attempts all with negative outcome.
I wanted to find a solution and therefore, as written in previous posts, I tried on multiple pcs, virtual machines, different operating systems, 4 different browsers (I could try a fifth :unsure:), the problem persists because it is a problem, known, of ptc.
looking in the ptc community threads, it seems that the only way to use the express version is to generate the temporary activation key valid for 72 hours, but that doesn't even work.link to the ptc community about activationI wonder, like others before me, why do they make a free version available if you can't activate it, will they be little toys? :rolleyes:
cmq if someone solves.... :
hi, same problem, ie I had to resort to the temporary activation key valid for 72 hours. the key works but then it will expire and then??
other problem: the Italian version?? Since there is no language pack apparently...
What a package!
was a super software. . .
p.s.
the registration was not good because there was no warning about which form (character ) appropriate for the password...
