problem automatic assignment current layer to existing objects
  • Thread starter Thread starter Big
Big
after applying a certain object to a layer, this automatically assumes the current layer property as seen from image qui. Can you tell me why this is happening to me? I press that it always worked well... maybe I set some variables I didn't have to?
to better understand, practically you draw an object on the current layer x, after changing the current layer x in layer z, and the first object drawn on the x automatically becomes changed in layer z?? ?
Yes, specific in details: if I design the doors and apply the layer doors this assumes the ownership of current layer, in fact as I point out in the attached image the check mark (the green one of the state) passes from zero layer to door layer. in practice this should not happen because even if I apply a new layer to an object the state (green check mark) should always remain in the zero layer. It is true that the state (check mark) can always move it from layer doors to put it back in layer zero but I do not see why autocad should move it automatically. I beg you never did.
some other information, e.g.:
Is this the sequence of operations?
- I prepare layers
- drawing the door
- select the door
- open the property palette
- change layer
- sending
which version of autocad uses
Are the doors blocks? and if yes, on which floor were drawn? or are they inserted from the outside?
the sequence of operations I carry out is this:
1- I prepare layers
2- drawing the door
3- open the owner layer and select the door by applying the door layer
the doors are not blocks and my version of autocad is 2007.
1- I prepare layers
2- drawing the door
point 3. you can't, from the layer manager, change layers to an object, but only from the property window, also because you've noticed that the object doesn't change layers.
You are perfectly right joseph, I mean from the property window in fact, I was wrong to say, I apologize.
Did you check that the door layer has become really current (i.e. if you draw a new object goes to the green layer) or is it just a layer manager pane display error?
only on new designs or even on already started drawings?
autocad mysteries... in a new file the problem no longer exists. the problem would be solved, I did not understand what might have caused the ark problem, for the moment it is ok. thanks joseph and planner for support.
