by saying by typing the.command with the keyboard in the bar? Is there another way?use the dist command if you don't want those options.. .
Where is it?Do you... type?? keyboard? ? ! !
What a bad action!
it seems that d+ sending should correspond to dist. if it is not that will be of + sending.. . .
hi, the bar already is active, in fact I usually read right from them, but it is annoying cmq to have all that information every time, in the previous versions of autocad did not appear, always using the command from icon, now I am used so, I just want to have the possibility to choose if to keep it or remove this information, apparently it is not possible? I tried everything to eliminate them.@piersanti
if the video information is too much you can still read directly from the text bar.
to expand it just press f2. to extract ctrl+f2.
In fact my problem is not to find the corresponding icon, it is that using just the distance icon, all this information appear that I don't need and just waste my time, I just want to know how to remove them once and for all, without having to use the esc command every time to finish the commandWhere is it?
and anyway somewhere there should be the corresponding icon, or if there is no dist command you can find it in the drop-down menus.
ok thanks for the advice :finger:, but already the icon is measuredgeomif you just can't pull off the icon (I repeat the concept that is slower to click an icon typing d+ send), replace the meager command with the dist command in the icon.
if you just can't disconnect from the icon (I repeat the concept that is slower to click an icon typing d+ send), Replace in the icon the command misurageom con the command dist.
:Smile: ok this I understood, I guess I don't know how to do then, since this command I don't find it. and cmq the problem arises even when I have to do the area, I just want to delete everything that appears after using the command that I do not care for at all. Thank you for your patience. kinda:mixed: :bekle: :bekle:
