problem con dmu kinematics
  • Thread starter Thread starter marcofa
marcofa
I did an update of the pc.
I have installed a solid state for I know and programs and 3rd data raids.
to do this they did a full image, deleted data and transferred know and programs to the solid.
then they took the data and copied them on the 3 raids.
It's 15 days that everything works well, until today that I wanted to make a simulation with kinematics.
after uploading my file on the workbench (already properly bound) I clicked as usual the conversion of the bonds together, but nothing happens and the bar tells me "it is not an accessible command" and equally for fixed part and joints.
Other workbench work, fem , sheet metal, wireframe... .
Can it be the fault of all the maneuvers made?
Do I have to reinstall or do I have a solution?
on the laptop I have the same cat installed where kinematic works: I'm thinking of copying catsetting and copying them to the pc. and always that no shit happens! !
Where are the catsettings in win7?
Thank you for your help
Mar
may be in: c:\users\(tuonome)\appdata\roaming\dassaultsystemes\catsettings,
but also in other position (depending on installation), you should do a file search
select the disk, open the folder, top right/click local disk write: catsetting
It may also not appear anything, if it is in a folder with hidden attribute, in such case you have to make all folders visible.
years ago
