gscav
Hello everyone, I wanted to ask you a problem that I still can't find a solution.
I would have the need to create custom profiles for the realization of multibody structures but with profiles whose section is characterized by a non-standard geometry.
I followed the instructions in the 2011 64-bit sw guide, drawing the profile section, saving it with the appropriate extension and inserting it into the appropriate folder.
when I go to associate the profile to the sketch designed to be able to generate the multibody structure sw mi diche that is not present the file in the project library (which among other things appears to me).
I also run the address through the file path management in options to the folder containing the profiles but nothing, the software recognizes the profile but when it has to draw it to then be able to pull the extruded returns me that message.
Hopefully in your hand I thank you for the attention given to me
greetings giulio
greetings giulio
