problem cutting on solid
  • Thread starter Thread starter dzalee
dzalee
good morning, I would have a small problem to realize a cut of depth 0.5mm and 2.5mm wide though following the solid part of the body...it will have to be a sort of ink but I can't realize it. help :smile::smile::smile:
in questo thread There are all answers to all questions... Trust me. .
especially in the line written in capital and red. .
I'm sorry I didn't think help could be a banished word. But I really can't do what I just want to ask for advice on how to do this
start putting the version of swx you use and possibly posting the part if you want an image advice is a little bit to give you directions.
then ok the version is sw12 and the file is attached here:) the cut is to be realized in the edges of the central window and will serve to create a sort of recessed
the message and its title are inexclusible, but it is contemplated, in regulation, a small presentation before posting the first post with request for help.
I suggest you insert the software version in your profile.
Back to your problem, can you do a pencil sketch of what you ask?
Can you tie the file?
not having the file I can not understand the complexity of the piece, but from what I can see, extrude the edge giving thickness.
