problem display drop down menu
  • Thread starter Thread starter tecnodoff
tecnodoff
Good morning.
I would like to ask you this problem:
when I go to create a new drop-down menu and apply in the customization window I have the problem that this appears, as it must be, in the menu bar but the disposition (saved in a profile file) of the icons and features of my profile are lost....
how do I insert the menu in my profile by implementing it? ? ?
thanks to all
When are they lost? when you return the profile you saved?
Does the new menu also contain custom icons?
You don't understand.
I apologize if I was unclear. . .
when, after creating the drop-down menu, I do "apply" and I return to the work screen the location of the icons varies....some even disappear.. and as if I applied the new menu to another profile. . .
I hope I've been clearer
...and, I forgot, if I go to restore the previous profile with the icons where I want, the created drop-down menu is not visualized in the work screen but and cmq present in the interface customization screen. .
and I don't understand why.. .
...and I don't understand why. .
because you do not know how the user interface customization works :biggrin:
... is absolutely normal behavior.
in addition to the menu you should also arrange the toolbars and make them permanently visible or not depending on the working area used
Thank you for your compliment! ;-)
told what I can find qlksa ke explain how to solve the problem? ? ?
