problem dopo a virus
  • Thread starter Thread starter FIGOR71
FIGOR71
Hello, everyone. .
After having taken a virus which began to rename all the files in the java extension, it happens that opening axioms in solidworks I find suspended parts with the yellow triangle next to it . (all concerning a specific folder on the net)
When I go to reactivate them, it tells me that the part is not found and therefore gives me the chance to search and insert it. (the fact is that the part exists) .. once reloaded a part, with the other parts it does not tell me that it does not find them, but it reacts immediately. .
My question is: is there no automatic way to get him to recharge the parts without all this round? even because if I open only the table I find so many errors and objects missing in the tables and I am forced to open all the times the general axieme and do as described above.. .
available for any questions. .
I felt bad. the file is already in solidworks extension.. is that there is a copy in java extension. .
I still don't understand the problem.
if there is a file with the correct money extension uploads that.
the java files eliminate them
the problem is that it does not charge it automatically. .
I said some virus because it happened after that. .
Maybe there's no connection between them. .
but of each solidwork file part there is a java copy... How come only those of the folder in question automatically put them on hold?
I repeat for the last time, then give in the match on this test please delete the java files and see what happens.
if you still don't upload files, right-click the file and check in the properties where the path is sought.
next together that I happen with control errors and keep you updated.
s
I'm sorry, I was a little lost, but it seemed right to answer you as I see you're always available...
I saw from the properties that the file search path was still reported to an old server drive, and putting the new one the problem was solved
Thanks again
